Regain wrote: Tue Mar 17, 2026 6:16 pm
I'm still not sure when I'll actually use this other than when I'm riding alone. Unless I'm much mistaken, and it seems I often am, sharing of a Tread route is only possible (or at least easy) between Tread users. My efforts so far to share via other means have only resulted in a straight line between points. I may be missing a trick.
There are no Tread app routes (in the strict sense).
It is probably, or very likely, not widely known that routes can only be shared among Tread app users.
In principle, routes can generally be exchanged via GPX files, and this also applies to the Tread app as a source.
If you only see “a single” straight line between the (start shape via end) points in the Tread app (and you didn’t select direct routing), just wait, sometimes for a few minutes, and Tread app will automatically turn it into a route.
Note! Multiple shaping points, e.g., >30, may Can the calculation take a long time or become a problem or even completely block the route calculation.
But you probably know very well how best to handle many shaping points.
So it would be nice if you could convert the Tread route to a track and share that way. Just so you could quickly share it around riders in your group to put on their own Zumo - I have friends on older non-Tread units. Maybe you can?
Then you can convert a route from the Tread app into a track file by visiting the Explore Cloud website; you can do that there.
Maybe you can convert a route into a track using the Explore app—I haven’t tried it yet, but I wouldn’t rule it out.
PS
You're welcome anytime, anywhere
