Has liked: 183 times
jfheath wrote: Sun Mar 15, 2026 9:25 am I am quite happy with how the XT2 behaves - and it is almost as good as the 590 - except for the changed route point names, and the RUT behaviour. Both of these are fixed by using TripManager to send the trip to the XT2.
The biggest irritant for me with the XT series vs the 590 is the faster roads algorithm, as that forces us into using shaping / waypoints to keep us on the route that Basecamp (for example) would have sent us on, and which the 590 would mirror.
One benefit of route planning with Tread is that it also prefers faster roads.
I am happy to use the Tread syncing with the XT2 as I can manage the problems it causes. I do this by importing the Basecamp route and its track into Tread, seeing where there's differences and then adding a shaping point where needed. Let Tread sync with the XT2 and see if the track and route still align, if not, add in a shaping point in Tread and let it sync again. I do the route planning in Tread as I find it more logical.
That this work around works for me doesn't mean it isn't going to be the best idea for someone else. I'll guess that the XT3 has the same routing algorithm's as the others as they include Tread in the adverts, in which case I begrudgingly accept that Garmin won't or can't fix the algorithm.
Regain
Has liked: 35 times
Been liked: 29 times
Post by Regain »
@jfheath you're correct, you didn't specify that exactly but you helped me to understand I would need more than one shaping point to avoid my route jumping to a faster road. A combination of that and MRA forum info is what I meant so sorry to besmirch you. I did notice that your trip between Carlisle and Penrith (approx 30 miles) had only a couple of points, one being at the beginning/end. My experience is that at least a couple more might be needed. That may be anathema to some but just the way it seems to be. Easily checked between platforms on your phone - well, with MRA anyway (sorry @proofresistant ;) ).
Has liked: 39 times
Been liked: 97 times
Germany
Post by proofresistant »
Regain wrote: Sun Mar 15, 2026 11:25 am ... trip between Carlisle and Penrith (approx 30 miles) ... My experience is that at least a couple more might be needed. ...
If the shapings are set properly, that few Shapes all you need.
Motto: “As few as possible, but as many as necessary”
Regain wrote: Sun Mar 15, 2026 11:25 am (sorry @proofresistant ;) )
@Regain and @jfheath ore others (me too) also,
Please let’s stay on topic :idea: :idea: :idea:
The other information about MRA and the number of shapings is certainly interesting.
But please start a separate thread for that, even though I’ve already mentioned it.
I hope you understand, and I don’t think that’s asking too much whishes.
Regain wrote: Sun Mar 15, 2026 11:25 am @jfheath you're correct, you didn't specify that exactly but you helped me to understand I would need more than one shaping point to avoid my route jumping to a faster road. A combination of that and MRA forum info is what I meant so sorry to besmirch you. I did notice that your trip between Carlisle and Penrith (approx 30 miles) had only a couple of points, one being at the beginning/end. My experience is that at least a couple more might be needed. That may be anathema to some but just the way it seems to be. Easily checked between platforms on your phone - well, with MRA anyway (sorry @proofresistant ;) ).
No apology needed - I'm just aware that people visit these threads in months years to come - so I do tend to correct things that I spot.
It is actually a very useful learning process. You see something, and you take what you think from it. Its handy to have it re-played to enable adjustments to be made.
On that point - here's another. That route from Carlisle to Penrith - I wouldn't even program the satnav for that route. The A6 is a superb riding road. It is the old main road north before the M6 motorway was built. It is twisting through the ups and downs of the hills between the English Lake District and the Pennines and because the motorway is so close it is relatively traffic free. And can be enjoyed at well within legal speed limits.
But it is also handy for testing purposes - because there is a motorway nearby. I just happened to use it when I first started trying to create routes on the Tread App. And I noticed that it was easier to plot via points first than it was shaping points. On the Tread App, I can control the order of via points, and move them around in the route after it has been completed. Not so with shaping points. I wanted a route than runs north south, 'cos the phone is tall and narrow.
Having created such a route I then changed the vias to shaping points, but noticed that when I did, the route points moved onto the motorway. Sometimes they didn't so I'd change another. And a third. When the third was changed all three of the shaping points jumped onto the motorway.
That behaviour still exists - but not the same behaviour every time. Curious though - if you undo the action with the undo button so that they are all Via points again, and then change them to shaping points, it doesn't do the same thing. If you undo again and repeat - it doesn't do it at all !!
So I tend to use that route to observe moving shaping points, and because I knew what it did on a previous version of tread, it is an easy test to carry out to see if that particualar behaviour has been fixed. It certainly isn't an example of how to plot a route.
If you want to know how I think routes should be created, take a look at viewtopic.php?t=521 and download the pdf The first chapter is all about route points and using them in routes.
I also covered it on these pages for the XT1 app.php/ZXT-P04
The text is still relevant for the XT1 and XT2 - as long as you do not enable Tread/Drive synch and you nobble the route to prevent RUT behaviour
(Resave Active Route on XT1, Copy Route on XT2) or use Trip manager.
Also - the drive north to Scotland in those links was the start of an actual tour that we did many years ago. I show that in those articles with Just 2 Vias and 3, 3 and 2 shaping points. The first two shaping points of the route were to ensure that it followed the A6 route that we are talking about. That is really all that is needed. If it tries to take me onto the motorway, I ignore it and continue - it will correct itself.
Has liked: 39 times
Germany
And do all these latest notes now relate to the topic “Latest XT2/Tread software version”?
I just don't understand it, may find my misunderstanding ;-)
Regain
Has liked: 35 times
Post by Regain »
@jfheath thank you, I think I’ll have a play with that section of road too as an experiment. I do ride it, usually in May of every year on the way home from the ferry.
proofresistant wrote: Sun Mar 15, 2026 7:43 pm And do all these latest notes now relate to the topic “Latest XT2/Tread software version”?
Well, sort of. My tests were carried out to find out if there had been a change of behaviour in the new version of Tread, and then answering responses. I’ll take a look at the possibility of moving some posts out - the thread is far too long to read through. But it is a non-reversible process and very easy to screw up- especially since I don’t do it very often.
I’ll see if I can find the first post for v3.00.11 and put those into a new thread and lock the current thread. In the next few days. Do a bit of pruning !
Regain
Has liked: 35 times
Post by Regain »
@proofresistant or just don’t worry about it. Any conversation or debate sat in a room takes twists and turns. I’m sure whenever the next version is released, this can all start again. It’s hard to speak if all you’re allowed to say is what you’re told to say.
Has liked: 39 times
Germany
jfheath wrote: Mon Mar 16, 2026 7:46 am Well, sort of. My tests were carried out to find out if there had been a change of behaviour in the new version of Tread, and then answering responses. I’ll take a look at the possibility of moving some posts out - the thread is far too long to read through. But it is a non-reversible process and very easy to screw up- especially since I don’t do it very often.
You’re kind of right, though.
But honestly, aside from my tests, I’ve personally been following these off-topic ramblings for days now, just out of personal interest, to see if anything has changed or even improved in the new version, and my conclusion is simply “nothing new (of relevance).”
Anyway, I’d leave the comments as they are; cleaning them up probably isn’t worth the effort.
Has liked: 39 times
Germany
Regain wrote: Mon Mar 16, 2026 8:24 am @proofresistant or just don’t worry about it. Any conversation or debate sat in a room takes twists and turns. I’m sure whenever the next version is released, this can all start again. It’s hard to speak of all you’re allowed to say is what you’re told to say.
Just because things are often the way they are, and it often happens that way, and many people do it suboptimally too, should we just let a suboptimal growth continue and not ask for improvement :?:
You can’t be serious :idea:
Then it’s far from anyone’s wish that someone shouldn’t say what they want to say :!: !
Everyone should express themselves (best way on-topic) about whatever they want :!: :!: :!:
But it’s may better to try to discuss things in a nearly structured way and where they belongm why not try that :?: ? (Even if my posts aren’t the best example of this right now, but I’m working on getting better.) :roll:
However, if well-intentioned advice is simply ignored or if suboptimal attempts are even glossed over, then one might want to consider whether that is actually polite or even respectful or not :-(
