WiFi problems
Swifty22
WiFi problems
Post by Swifty22 »
Hi
This is my first post, unfortunately it's regarding an issue with my Zumo XT2.
I got my XT2 for Christmas and followed the start-up process with any issues, I got a new phone that was compatible with the tread app and paired it to my Zumo.
I also had a map undate to do while pairing, however! Idon't have WiFi connection and the screen is blank on searching for WiFi.
I've manually inputed my WiFi details and password but it will not connect, WiFI has been enabled but can't select saved networks and noting shows on search for networks even with the Zumo sat beside the router?
Does anyone know how to fix this please, it's doing my head in.
Has liked: 39 times
Been liked: 97 times
Germany
Re: WiFi problems
Post by proofresistant »
May the same problem like my.
5 GHz wouldn't supported.
May 2,4 GHz WiFi enable in your Router helps.
Has liked: 137 times
Been liked: 127 times
Re: WiFi problems
Post by smfollen »
Welcome to the forum @Swifty22
I have not experienced this, nor do I remember anyone else posting about it. Not much help, sorry.
Perhaps your XT2 has a WiFi hardware problem? Hardware failures "out of the box" are rare but they can happen. Garmin Product Support is generally good about dealing with hardware issues. Product.Support@Garmin.com
You can do map and software updates by connecting the XT2 to a computer with a USB cable and use the Garmin Express software on the computer.
twowheelstom
Has liked: 146 times
Been liked: 54 times
Re: WiFi problems
Post by twowheelstom »
Do not use 5G wifi, use 2.4G, 1st test with your router to make sure that it is working on 2.4G
Zumo 396
1994 Yamaha 250
Swifty22
Re: WiFi problems
Post by Swifty22 »
Thanks for all the advise
I connected the Zumo to my pc updated my Zumo and now have WiFi connection again, maybe there was a fix in the updates?
Has liked: 39 times
Germany
Re: WiFi problems
@Swifty22
It works now, fine!
Can you tell us, which kind WiFi your zumo using now ?
2,4 GHz or 5 GHz?
twowheelstom
Re: WiFi problems
for the Garmin XT2...
USA: 5 GHz Wi-Fi is supported.
Europe: 5 GHz is not supported for Wi-Fi, meaning European users must use a 2.4 GHz connection
Zumo 396
1994 Yamaha 250
Has liked: 39 times
Germany
Re: WiFi problems
twowheelstom wrote: Thu Mar 12, 2026 8:48 pm for the Garmin XT2...
This explains my observation, or rather my unsuccessful attempt to use 5 GHz Wi-Fi, even though 5 GHz Wi-Fi is described in the Garmin specifications.
@Swifty22 ,
can you also confirm that you only see 2.4 GHz Wi-Fi on the zumo?
Or do you also see 5 GHz Wi-Fi?
Has liked: 39 times
Germany
Re: WiFi problems
One more question: where does the information “Europe: 5 GHz is not supported” come from, or where can I read it?
twowheelstom
Re: WiFi problems
proofresistant wrote: Thu Mar 12, 2026 9:39 pm
https://support.garmin.com/en-US/?faq=N ... XiopghB9g8
Zumo 396
1994 Yamaha 250
