Introducing TripManager
- Has liked: 183 times
- Been liked: 166 times
Re: Introducing TripManager
Just a small note on avoidances, the touch the top bar when routing and then the icon to the left shows what avoidances it is using.
Not yet seen whether this area will also show the routing type, eg fastest / shortest so far, which if it does, will be very useful.
Version V1.5.0.320 has just been released on GitHub. https://github.com/FrankBijnen/TripManager/releases
The list of changes is quite long. To name a few: 64 Bits support, better handling of MTP devices, Import/Export from/to CSV format, automatic compare .trip with .GPX files, more base layers added to the map, and much more.
Downloadlink:
https://github.com/FrankBijnen/TripMana ... V1.5.0.320
Issue list:
https://github.com/FrankBijnen/TripManager/issues/15
Important info, for people like me, that dont read all documentation first:
- If V1.4 is installed on a 64 Bits Windows, the installer will prompt you to uninstall that version first. You will not lose your settings.
- The buttons 'Transfer to device' and 'Additional files' have been replaced by 1 new button: 'Send To'.
Many thanks go to @jfheath, @Peobody, @smfollen and @proofresistant for their ideas, testing and valuable feedback.
Frank
Downloadlink:
Issue list:
Frank
@smfollen has updated his users guide for V1.5. You can find it here: https://htmlpreview.github.io/?https:// ... /README.md
Thanks Steve!
Thanks Steve!
- Been liked: 560 times
@smfollen,
Ditto!
- Has liked: 137 times
- Been liked: 127 times
- Contact:
Comments / suggestions / enhancements for the User's Guide always welcome.
Anything not clear? Anything missing?
tombarrington
- Has liked: 14 times
- Been liked: 15 times
I may have missed it. Is there a log of sorts that summarizes the changes between versions of the User Guide? I keep a copy of the April 6, 2025 version and I don't think there have been major changes to TripManager since then. I have an XT and it seems the more recent developments are to better support the XT2.
Thanks for the great work!
2022 BMW R1250 GS
2002 BMW R1100S
1984 Honda VF700F
1969 Moto Guzzi Ambassador
2002 BMW R1100S
1984 Honda VF700F
- Contact:
@tombarrington Good point.
There is a brief summary of changes to Trip Manager on page 3 and a link to more details there, but that is more about Trip Manager itself, not changes to the User's Guide.
Attached is a pdf that flags document changes between V1.4 and V1.5. (Thanks to Word's document compare function.)
- Trip Manager Users Guide_V1.5 Changes.pdf
- (1.76 MiB) Downloaded 112 times
If you have a copy of April 6 then that is the Guide written for V1.3.x.yyy. Current version is V1.5.x.yyytombarrington wrote: Mon Sep 08, 2025 9:20 pm Is there a log of sorts that summarizes the changes between versions of the User Guide? I keep a copy of the April 6, 2025 version and I don't think there have been major changes to TripManager since then.
Look at the main page for the most important changes: https://github.com/FrankBijnen/TripManager
If you see the changes listed under: Changed with V1.5.0.320 and Changed with V1.4.0.162 you will find multiple changes applicable to the XT. (I myself have an XT, so will not forget that model)
And of course Steve's guides reflect the changes in the program.
You can, if you like, follow this link to download a specific version: https://github.com/FrankBijnen/TripMana ... s/SMFollen
tombarrington
Thank you, Frank. I have version V1.5.0.320 so my documentation is lagging. I'll download the current User Guide. Thanks to everyone who has contributed to this great utility.
2022 BMW R1250 GS
2002 BMW R1100S
1984 Honda VF700F
2002 BMW R1100S
1984 Honda VF700F
giuseppe66
- Has liked: 27 times
- Been liked: 9 times
Sorry if my English isn't correct, but I use Google Translate. I'm not very experienced with TripManager, but I wanted to ask a question. I have an XT2. I can correct the RUT with your program (thanks a lot) by selecting the .trip file, but I have many GPX files that I download via Myroute in 1.2 format (but I can use 1.1 format if you recommend that). I have the files on my computer and wanted to correct the RUT directly on the GPX files before inserting them into the XT2. Is this possible? Thanks for your reply, and sorry if this is a question others have already asked.
