A couple of thoughts.Biker PG wrote: Sat Oct 04, 2025 6:25 pm Hi,
I did post earlier this year about the issues I was having playing music. I managed to resolve it to a degree, but an issue remains…
My music is stored on a SD card in the XT and generally plays well for much of the trip, but occasionally it becomes choppy and either stops altogether, or will recover and start to play clearly once again. If it stops, my headset turns off! (It’s a Nolan B601-R made by Sena, and yes it does have a function whereby it will switch off if no BT signal is received, but only after 5 minutes, not immediately! In any case, I’ve disabled this function..). If however the music recovers and becomes clear again, the spoken navigation voice then becomes croaky/crackly for the rest of the trip, unless I turn the headset off & on again after which it’s crisp and clear once again (until the next time!).
I think it’s likely to be the headset getting BT interference, especially as I’ve tried it with my phone disconnected from the XT without success. Still can’t understand why the music continues to play crystal clear but the nav directions are audible but very crackly
Phone is a Motorola G73 running Android 14, and both this and the XT have up to date software.. Headset is connected to XT, and phone is connected to XT (Drive App) with ‘Media Audio’, ‘Phone Calls’ and ‘Contacts and Call History Sharing’ all activated. There are no other BT connections..
Wondering if anyone else has similar things happening?
Cheers, Paul
Why do you need media audio activated on your phone, if you are playing music from the SD card on your XT ?
Is your Drive app set up so that it can synchronise with the XT ? You will know by selecting Where To -> Explore. If you get a menu with 3 icons and a Connect Now button, then Explore Synch is not enabled.
But my guess is that it is enabled. So the BT will be working overtime talking to the XT. Which might be the cause.
The solution to that (at least to try it) is to kill the Explore link. But there are 2 things that you need to know first.
1. Do you plan your routes in the Explore App ?
2. Do you use Collections ?
The reason for the question is that if you do what I am about to suggest, then you will lose both of those facilities. You can still use the Drive app to transfer routes etc (eg by opening from your phone using the drive app). But collections will not be available. But it will still control alerts and phone calls and get data regarding traffic and weather and up ahead places. It just won't synch. Which from me was perfect. Just perfect.
The other issue is that you have to delete the Drive App from your phone, and perform a system reset of the XT1, and then reinstall.
When you reinstall the Drive App do not say yes to any request to share or synch data with Explore. Read the questions carefully - including the one that you can hardly read. That is the one that you have to be careful answering.
Resetting the XT1 to factory - is not a problem - but you will lose settings and some data. If you like to keep your active log files, then take a copy of CurrentTrackLog.gpx and of the archive folder that is in the GPX folder. They will be wiped during a reset. IT does not afect maps, but it will probably get rid of any loaded routes. Nothing on the SD card is affected. Maps are not affected.
Read the info on this page carefully.
app.php/ZXT-P56
