I apologize to you and the others for seeming to be so dense on this. As I said in my initial post, I thought that I had this all figured out.
The zumos are complex and they have their quirks. We are all still learning. If it was easy, this forum probably would not exist.
... I have been able to avoid using CEP altogether.
I use CEP to start almost every planned ride, usually with good results, but on occasion, it does something strange, and I learn something new. After starting CEP, I take a look at the resulting overall route before starting off (Settings -> Driver Assistance -> Route Preview), to make sure it makes sense.
As
@Peobody suggests, sprinkling in a few via points is good practice so you always have an option if things go wrong.
I am still left, though, with why the Zumo would not follow the route. I was on the magenta line when I selected closed entry point. I understand that it did not know what direction I was heading in. So, it seems that it selected a point that was behind me - presumably also on the magenta line. If I am correct so far, why would it not simply pick up the next shaping point on the line when I started moving. I thought the value of shaping points was that I did not need to pass through them and that when I did not, the Zumo would continue to guide me on the route ahead of me.
You touch on multiple things here.
I have no way to know what specifically happened in your case here but I can offer some thoughts.
First, as I
@jfheath and I said above, CEP tries to go to the closest point on the magenta line, not the closest shaping (or via) point. That makes sense. It is trying to get you onto the route as soon as possible.
Were you on a divided highway? GPS is impressively accurate but not perfect. It can get your position wrong by several meters, especially if you are stationary. This is even more true when the GPS receiver first starts up. It can get a "fix" with 3 satellites I believe but becomes more accurate as it acquires more satellite signals, which can take a few minutes. My point here is this - Is it possible that zumo "thought" you were on the opposite side of a divided highway so that you had to go to an exit / entry ramp to get turned around?
Is there any chance your route included a point on the wrong side of a divided highway, a point at an intersection, a point off the road?
I believe
@jfheath has previously posted about CEP being confused if it is started while already on the route. I have not had issues in the case, but again CEP does seem to do strange things on rare occasion.
Yes via points must be skipped explicitly while shaping points can be skipped automatically (There is Settings -> Map Display -> Skip Next Stop Confirmation), but that does not affect the selection of the closest entry point. It only applies once you begin to navigate a route. Any part of the original route prior to the selected closest entry point is ignored.
So, I guess a better question is, if you were sitting at shaping point 10989 and wanted to head toward shaping point 956, what would you tell Zumo, keeping in mind that the only starting point options I was given were two that were very close to the starting point and CEP?
I would have done exactly what you did at that point. CEP was your only option, other than selecting the via point at the end of the route, which would not have helped in this case.
For future planning, options include:
- sprinkling in via points
- checking the planned route carefully at close zoom level to make sure all points are on the road, on the proper side of a divided highway and not at an intersection. Also be sure your route does not involve u-turns (e.g a point on a dead-end street).
- breaking a loop route into two parts, out and back
- keeping the zumo turned on, even when not following a route.
One final question on this. Is it best to have u-turns turned on?
I typically do allow u-turns. Without them, the zumo can route you a long way to get turned around if there are no nearby roads that could loop you around. As far as I know, allowing u-turns does not affect CEP's selecting of the closest entry point; it only has affect if you are already navigating a route and go off route. (U-turns can affect RUT I think, but that is another subject entirely.)
