It takes a long time for me when I have a lot of routes on the device.Oop North John wrote: Wed Sep 03, 2025 7:48 pm Is anyone else seeing vastly poorer performance with Express and connecting to their XT2 recently?
It takes 5+ minutes to connect,
It got really bad after I had synchronization problems with the Tread app, where I had multiple identical route (trip) files internally.
I personally have not yet observed any reboots during the connection.Oop North John wrote: Wed Sep 03, 2025 7:48 pm and often the XT2 will restart the connect to the laptop after it's already showing the PC icon etc.
There are two connection statuses:
1st the zumo XT2 screen appears slightly brighter while the zumo XT2 is “preparing” the connection
2nd the screen becomes slightly darker when the connection is established
It is not longer displayed as a drive letter on my computer since "MTP" was implemented, but you find your device as "zumo XT2" in your ExplorerOop North John wrote: Wed Sep 03, 2025 7:48 pm And, also doesn't show as a drive either in file explorer.
(the reason for the missing drive is the newer type of “MTP” connection with Windows).
What do you mean by “And hangs onto showing the icon for minutes after you disconnect it.”? Do you remove the cable?Oop North John wrote: Wed Sep 03, 2025 7:48 pm And hangs onto showing the icon for minutes after you disconnect it.
