XT2 turns off and restarts
Multirider
Post by Multirider »
Unfortunately the more you read the more you realise that the XT2 like just about every other Garmin ZUMO is flawed, I’ve had almost every version since the original Quest (that’s around 20 years ago and they swapped that twice due to problems) and not one has worked perfectly, at one time or another every one has crashed and although I wouldn’t be without one you just get used to dealing with it and carrying some sort of backup.
Yes - but I've been using the Zumos for nearly as long - the 550 was my first. I've never had any of the units crash like that.
Although ----- I did have an issue a little while back with phone calls - the BT wouldn't let go of the phone. After a short while it would do a soft reboot, and then continue navigating from where it left off once it had restarted. That was a Tread / Android issue. A later phone cured it, but I also stopped using Tread synchronisation at the same time.
@FelixHauser - do you have Tread installed on you phone to synchroise with the XT2 ?
FelixHauser
Germany
Post by FelixHauser »
jfheath wrote: Sat Aug 16, 2025 2:41 pm @FelixHauser - do you have Tread installed on you phone to synchroise with the XT2 ?
Certainly. Sometimes it shows some "Sync not Working" or something of the sort, but most of the times it works ok. I'm an iPhone 14 Pro user, by the way.
Multirider
The move to Tread, which wasn’t very many years ago was applauding. You only have to look at the app responses.
It’s improved, but syncing is still very clunky.
Basecamp, though no longer supported by XT2 is still by far the easiest way of route planning anything with a number of waypoints so as to stay on a very specific route. And planning a week of routes in advance is dreadful with Tread, takes forever and the phone screen is too small.
595 was one of their better upgrades.
But if you use a ZUMO at some point it’ll tie itself internally in knots and fail. But I’ve had a Tesla, drive a Range Rover and ride a Ducati - I’m used to these little annoyances :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Allanashley
Post by Allanashley »
The thing is, does the Zumo reboot because of memory issues, or is this a hardware issue.
If it’s the latter, then is there any hope other than replacement?
I keep the files in memory to a minimum but the unit still reboots, 20 times in a 2 hour ride, even when not following a route.
Can’t believe that there isn’t someone at Garmin who knows all about this issue and the reasons for it.
They are sending me a replacement next week so will let you all know what happens.
If it reboots again I will be selling it and getting a Chigee.
Multirider
All my music is on sd card
Resets happen with no routes or tracks in the memory
It’s either a hardware or poor coding problem.
turbo19
Has liked: 193 times
Been liked: 47 times
Andorra
Post by turbo19 »
Allanashley wrote: Sun Aug 17, 2025 12:55 pm The thing is, does the Zumo reboot because of memory issues, or is this a hardware issue.
Reboots with the latest software version are caused by software issues. There haven't been as many reboot issues with previous versions like 5.40 (the version many people have downgraded to).
When I installed version 6.10, I was going crazy because the same thing you're describing was happening to me: it rebooted every few minutes and was unbearable. I managed to fix it by disabling Bluetooth on the XT2 in the phone's connection menu.
You can sync whatever you want by turning on Bluetooth, and after syncing, turn it off again.
This way, no problems on several long routes completed this month.
Garmin is already aware of the problem, and will surely update the XT2 software soon (it's taking too long). As @multirider says, the synchronization system is very poor, slow, and bad.
FelixHauser
Germany
Here is the answer from my inquiry to Garmin (translated from German):
Thank you very much for your inquiry.
There is no specific information, such as a maximum length for tracks.
This always has to be considered individually from GPX to GPX.
In most cases, the issue lies with a particular GPX file.
We generally recommend keeping the devices “clean” and only transferring the necessary tracks.
We usually cannot make concrete statements about individual sample routes—among other reasons, because we do not run tests with third-party planning software.
Based on experience, using tracks on the zumo usually provides the best results. The reason is that the calculation or conversion of the route takes place directly on the device. The procedure is as follows:
Export the planned route as a track (.gpx) → import it into the Tread app → synchronize with the zumo XT2 → calculation/conversion of the track into a route on the device.
Each new route or track may behave differently. We therefore definitely recommend checking the route on the device after calculation to ensure it matches your requirements and expectations. Adjustments afterward may also be necessary.
FelixHauser wrote: Tue Aug 19, 2025 4:55 pm
I would have to object to this response as being unresponsive to the issues you are having.
There may be no "maximum length" (distance) for a track, but there is definite limit on the points per track. The limit for an XT is 15,000 points per track and I cannot imagine the limit for an XT2 being less. It is very difficult to exceed the points limit in a single session. Even on your long 495km day, you surely stopped at some point, starting a new track. If you have a true iron butt and a very large fuel tank and can exceed the limit, the GPS should be able to save the track and start a new one without crashing. There is also a limit to the number of unsaved recorded tracks (20, I think) but if you exceed that number, the oldest one is just deleted, without any other effects. Importing a too-large track should only result in a shortened track of the first 15000 points, with the rest ignored.
FelixHauser
Germany
lkraus wrote: Tue Aug 19, 2025 7:09 pm I would have to object to this response as being unresponsive to the issues you are having.
I also find the lack of interest disturbing. Here is the response I sent:
Dear Garmin Support Team,
Unfortunately, your response was of absolutely no help to me. The suggestion to keep the device “clean” is particularly amusing, since I already mentioned in my original request that I only keep the necessary files on the device.
In addition, you did not address whether Garmin is even aware of this problem and whether any steps are being taken to resolve it. Just to be clear: I am very well aware that I am not the only one experiencing this issue. For example, here:
viewtopic.php?t=2315
and also here:
https://www.advrider.com/f/threads/garm ... s.1643705/
I was especially surprised by your statement (I quote): “we do not perform tests with third-party planning software.”
Allow me to follow up here: Why did Garmin even implement the function to import GPX files in the first place? If you neither test how GPX files from third parties behave, nor clarify what limitations exist regarding storage or route length, then what exactly is the purpose of importing them? And from which source?
At this point, I would really appreciate some more clarity—or at least that my ticket be forwarded to one of your software developers. I am more than willing to provide the GPX files that cause my device to crash.
I must also say that I am rather disappointed. I already spent more than €600 on a BMW Navigator 6, which became unusable after two years due to display ghosting—and now I am facing similar problems with the Zumo XT2.
I look forward to your reply.
I checked, and I got my unit in July 2023, so I don't think I am entitled to a replacement. I also believe very strongly, that this is a software issue and hardware has nothing to do with it.
