Kaj pa pravi skriti meni naprave, kjer se nadaljuje način povezave USB (nastavitve MTP)?
Moderator: English Please ! Translation below:
But what about the hidden menu of the device where the USB connection mode (MTP settings) continues?
Won't connect to computer
Re: Won't connect to computer
That is Ok. Is everything working Ok now ?
Nope, still working on it. @raza just sent me a procedure of Master restart but, ether I am doing something wrong or the device is ready for the bin, since I can't access the menu at all, or again, I am doing something wrong. The procedure goes as follows
- Hold power button for a few seconds
- Hold it again until Garmin logo appears, then let go of it
- Press it once more
Dim menu should appear
- Using the power button select option A03
