396LMT-S No Voltage at the cradle connector
Fxwheels
Has liked: 30 times
Been liked: 31 times
Re: 396LMT-S No Voltage at the cradle connector
Post by Fxwheels »
twowheelstom wrote: Thu Apr 24, 2025 9:29 pm
Fxwheels wrote: Mon Apr 21, 2025 11:32 pm Have you got the new power cable?
Yup, got the new power cable.
Sorry FXwheels, I was away from the computer a few days, had dental surgery.
Ya I installed the new 396 power cable, and thanks to the wiring diagram for my bike model, found a switched power wire that feeds the left-front running lamp bulb, so I tapped the new power cable onto that switched wire using a posi-tap connector. So now my Zumo comes on when the ignition key is on, everything works great.
Thanks for the update twowheelstom. Keep us posted on how it'll behave.
Wallace
Been liked: 3 times
Post by Wallace »
I have been making very slow progress with my connection problem.
I spent some time last week making a new plug out of Milliput modelling clay and plan on using a hobby drill to make a cavity to house a set of pogo-pins to make the new contacts.
I make an interesting discovery, while trying to get the Milliput out of the connection cradle. There is a small magnet placed inside the cradle in the same corner as the release button.
I wonder if I connected a power cable to a computer and placed the Zumo in the cradle, would make the Zumo function as a charger (from the computer) rather than a computer connection?
QED I suppose.
jones9999
Has liked: 4 times
Post by jones9999 »
It looks as if this may be the same problem as this subject on this same forum here .....
viewtopic.php?t=1727&e=1&view=unread#unread
