Software 6.10
turbo19
Has liked: 193 times
Been liked: 47 times
Andorra
Re: Software 6.10
Post by turbo19 »
I answer to myself.
It seems that when a track is synchronized, the Treat app and the XT2 look good. But...
But when I go to the explore website I see that the track is in the unorganized folder even though it looks fine on our mobile and XT2.
This discrepancy between the Tread app and the Explore website causes syncing to not work properly and the XT2 to restart from time to time.
The only solution I have found is to go to the Explore website and manually delete that track from the unorganized folder
:cry:
Lk77
Has liked: 7 times
Been liked: 5 times
Italy
Re: Software 6.10
Post by Lk77 »
I sent a reminder to garmin helpdesk about this issue, and this is the answer I received today:
"Hello,
Thank you for reaching out. I do understand your frustration with the Custom POI's not appearing as advertised. It does look like the 6.10 software update did clear this feature. We haven't forgotten about you, this ticket has been escalated to our Engineers and Field Quality Control team. This issue is still being actively investigated. I apologize on Garmin's behalf that this is affecting your work."
Gelo
Has liked: 32 times
Spain
Re: Software 6.10
Post by Gelo »
Hello,
Today, 26/09, I received a software update, but the XT2 is still running version 6.10.
Does anyone know what this is about and if it includes any new features? :roll: :roll:
Lk77
Has liked: 7 times
Been liked: 5 times
Italy
Re: Software 6.10
Post by Lk77 »
I just got this update
Update
Update
Re: Software 6.10
Gelo wrote: Fri Sep 26, 2025 8:44 pm Hello,
They alert that there is software update when it is something like data files - eg Cyclops. The system software remains the same.
Gelo
Has liked: 32 times
Spain
Re: Software 6.10
Post by Gelo »
I hope you fix once and for all the problem of custom POIs not appearing on the screen and only responding with completely ridiculous questions. They are a permanent disaster. :twisted: :twisted:
At the time, they responded with this nonsense:
If certain custom points of interest (POIs) are not displayed on a device after being transferred by Points of Interest (POI) Loader , and if your custom POIs are categorised, ensure you select the correct category when searching for a POI on your device.
Use POI Loader to reload the .gpx or .csv file containing the POIs.
If you receive an error message, see the FAQs below or visit our Support Centre for more solutions.
If you are using a mass storage device, open the POI folder to ensure it contains a .gpi file for the POIs.
If you are unsure whether your device is a mass storage device, see Related Content for lists of devices that use mass storage mode.
Some locked POI files may have an associated unlock file (.unl). Check the source of your POIs to see if this file is necessary.
Re: Software 6.10
I reported the fault on 29 June 2025.
I pointed out tot hem that POIs worked perfectly well on v5.40 of the software. It was version 6.10 that stopped them from working - and I rolled back my system software to v5.40 to verify this.
ON 1 September 2025 they told me:
We have opened a new investigation which will be used to determine the cause of this issue which we are looking into currently. Using the information provided they will test and reach a suitable resolution which will then be supplied to you directly by email.
We cannot provide a time frame for this process as it depends on what is discovered during the investigation and what is required to resolve the issue
My Reference number is 30458259K1.
I know that other people have complained as well.
Please contact them again. So will I - I don't understand why front desk are telling customers to jump through hoops when they have opened a new investigation.
Gelo
Has liked: 32 times
Spain
Re: Software 6.10
Post by Gelo »
Today I received a software update for the XT2, but even after installing it, version 6.10 still appears.
Does anyone know if there are any new features?
Thanks.
Has liked: 183 times
Re: Software 6.10
Gelo wrote: Mon Nov 03, 2025 4:10 pm Today I received a software update for the XT2, but even after installing it, version 6.10 still appears.
Thanks.
Only update I see is for the Cyclops speed cameras.
Lanso
Been liked: 16 times
Belgium
Re: Software 6.10
Post by Lanso »
The only software update i receive today:
"Time Zone Map"
Version: 40.00
File Size: 873kB
  • A NEW time Zone covering the Aysén Region, America/coyhaique, was created to stay on permanent DST
Bike: BMW R1200RS 130.000km
