Waypoint Names changing??
Exrm193
Post by Exrm193 »
I am using My Route App to plan routes.
I change some waypoint names to cafe, petrol etc etc.
I save as a 1.1 .gpx file and send it to Garmin Drive which then sends it to the Zumo.
Waypoints are in the right place, but sometimes names change to "Area" or just the co-ordinates.
Any idea why?? Is this a Garmin thing or My Route App??
cheers
Has liked: 203 times
Been liked: 286 times
Re: Waypoint Names changing??
This is a 'Garmin thing', more specifically an XT, and also XT2 thing.
But there are thechniques to overcome that. Probably the easiest is to use TripManager, if you're using Windows.
Zumo User Forums link: https://www.zumouserforums.co.uk/viewtopic.php?t=3150
If you want to prevent renaming use the Transfer to Device method 4 or 5 as described in https://raw.githubusercontent.com/Frank ... Device.pdf
Note: TripManager has been tested with MRA Export GPX 1.1
raesewell
Been liked: 20 times
Post by raesewell »
The XT changes the name to "Area" if the pin is not on a road recognised by Here maps.
