Java (RUT) Question
Scarecrow
Been liked: 28 times
Java (RUT) Question
Post by Scarecrow »
Sorry Guys if I've missed this but,
If I run a route through the Java program, do I have to do it again if I send the route to another XT
Has liked: 202 times
Re: Java (RUT) Question
Depends on how you send it to the other XT.
- if you copy the modified .trip file to the 'internal storage' of the other XT, there is no need to run the program again.
- If you send the trip from one XT to another XT using the 'Share' method. Yes, run it again.
The method to verify is to check if the trip is listed under 'Imported' or 'Saved' on the XT you're sending to. It should be under Saved.
If you are a Windows user, also check out TripManager. https://www.zumouserforums.co.uk/viewtopic.php?t=3150 IMHO It can fix the trips the most easy way, and much more.
Frank
electro_handyman
Been liked: 41 times
Post by electro_handyman »
Another question to answer on that issue is about the map on the 'other' XT.
Are the map versions identical or not.
Scarecrow
Post by Scarecrow »
Ok Thanks Guys that's the conclusion I came to but thought I'd check with the Masters :)
