Introducing TripManager
HarryMJ
Has liked: 6 times
Been liked: 3 times
Denmark
Re: Introducing TripManager
Post by HarryMJ »
FrankB wrote: Sat Feb 08, 2025 10:37 pm
I had a look at the site. Looks 'Scandinavian oriented' to me. Can you use it practically when you're not a 'pro user'? (We from Holland dont like to pay!)
The export is first available as a 'pro user', so I just signed up as export is essential to me, so I am not sure how useful it is without being 'pro user'.... and you are right, mostly Scandinavian.
Same here in Denmark, do not like to pay, so mostly on open software, so therefore only on MSWin when absolutely necessary, for example when finding a great tool like the TripManager :-)
Brgds. Harry
Zumo XT
Route planning in QmapShack / TourStart / CaliMoto / BaseCamp / TripManager
Honda NC700 XA
HarryMJ
Has liked: 6 times
Been liked: 3 times
Denmark
Post by HarryMJ »
FrankB wrote: Sat Feb 08, 2025 10:35 pm
Here you go. Version V1.2.0.123 should fix it.
https://github.com/FrankBijnen/TripManager/releases/
@Peobody
Also excluded way points from stripped routes.
Amazing, this is now working :-) :-) ...what a quick response :-)
Brgds. Harry
Zumo XT
Honda NC700 XA
Has liked: 202 times
Been liked: 285 times
HarryMJ wrote: Sun Feb 09, 2025 10:10 am Amazing, this is now working :-) :-) ...what a quick response :-)
You're welcome. Any other feedback you have is also welcome, that includes the docs.
As mentioned in the Docs, it needs to be tested, and likely, updated for the XT2. I myself only have the XT at my disposal. If you know people owning an XT2 and dont mind experimenting, convince them to try TripManager.
Frank
@FrankB, on 7 February I claimed that a skip recalc resulted in a change in the route. That claim was incorrect. I re-road that route and experienced the same deviation from track that I did on my last ride, when I did a skip. There was no skip on this ride. I finally figured out that the deviation was there all along. It took full zoom to see it when comparing track to route. I apologize for not having dug as deeply as possible when I first looked at this.
Peobody wrote: Thu Feb 13, 2025 7:28 pm I apologize
Not needed at all. But accepted.
Edit: As a side note: Meanwhile I saw a few posts from @jfheath that pressing 'Skip', will recalculate the entire route, often with a very different outcome. One of the reasons why I use VIA points sparingly,
FrankB wrote: Thu Feb 13, 2025 8:23 pm Edit: As a side note: Meanwhile I saw a few posts from @jfheath that pressing 'Skip', will recalculate the entire route, often with a very different outcome. One of the reasons why I use VIA points sparingly,
Yes, but TripManager triggers a calculation on first load of a transferred trip so I think it fair to assume that a recalculation triggered by a 'Skip' will be the same as the original calculation. Of coarse all bets are off when routes are recalculated as a result of a map update. Two of eleven of mine ended up being different following the update to CN NA NT 2026.10. I did not see a logical reason for the new route going the way it did. Maybe in the new map the speed limit had been increased on the newly selected roads.
I must say that fixing those two routes by shaping them on the XT was very easy. I duplicated those fixes in Basecamp (added the shaping points) but did not bother doing another transfer. I don't recall doing a recalculation in Basecamp before adding the shaping points so I don't know whether Basecamp would have produced the same route change.
Peobody wrote: Thu Feb 13, 2025 10:54 pm so I think it fair to assume that a recalculation triggered by a 'Skip' will be the same as the original calculation.
It is the best strategy I can think of.
For anyone who is interested in the latest version. Just released build 137. https://github.com/FrankBijnen/TripManager/releases
Frank
New version available V1.3.0.147, with support for the XT2.
Read the release page for more info:
Massive thanks go out to John @jfheath, without his help this release would not have been possible.
Also worth nothing that Steve @smfollen has volunteered to write a User Guide.
Frank
Update April 6, 2025:
Please have a look at the users guide created by Steve Follen. It includes screenshots from the XT2.
https://raw.githubusercontent.com/Frank ... 0Guide.pdf
