Basecamp with latest IOS Sequoia
Niro
Thailand
Post by Niro »
I am using Basecamp on a MacBook with Sonoma 14.06.01 togheter with a X2 and it just works perfectly. No problem connecting the X2 and no problem planning or following the rutes I made in Basecamp. I recently upgraded from a Zumo 395 which I used for 8 years. I really like Basecamp and I hope I can keep using it.
But I worry that upgrading the MacBook IOS to the latest Sequoia will give me problems. Anyone who has tryed?
dhwalt
Re: Basecamp with latest IOS Sequoia
Post by dhwalt »
Recently updated from an M1 iMac (Sequoia 15.0 then 15.1) to M4 Mac Mini (ex delivery with 15.0 then requiring 15.1 for the USB-C BT peripherals). I am using Basecamp + AFT and no issues even after the OS migration. Keep Maps and Express updated. The above using a Garmin XT2 unit.
Dave
Niro
Thailand
Post by Niro »
New IOS Sequoia 15.1 works perfect with Basecamp and my XT2 connects without a problem. I can create routes and waypoints in Basecamp and just drag and drop them to the XT2.
finerone
Post by finerone »
Glad to hear Basecamp and your XT2 are working smoothly on Sequoia 15.1! It's always reassuring when an OS upgrade doesn't mess up your workflow. Thanks for sharing your experience - it'll help others who might be hesitant about updating.
epv
Post by epv »
I am finding that Basecamp is not usable on my Sequoia 15.2 M2 Macbook Pro - very frequently the window vanishes, and MacOS offers to send a crash report. I can sometimes manage to create a very small route but most manipulations of routes cause the crash. I wonder if there's something weird going on with my Basecamp install, since it seems like other people are using it successfully. I don't have much preserved data in it so I suppose wiping and reinstalling wouldn't be that awful, but I'd like an idea if it works ok for anyone first, I guess.
Bernie
Has liked: 19 times
Post by Bernie »
I am using Garmin BaseCamp Version 4.8.13 for Apple with City Navigator North America NT 2025.2 with a very large data base of several hundred routes and thousands of WayPoints with no problems.
I am using a MacBook 16 with a M3 Pro Chip and 36 GB Ram and macOS Sequoia 15.3 with no problems.
The only issues I have is when I try to eject my BMW Nav6 GPS.
I can import routes, export routes as GPX with no problems.
Maybe it has something to do with your Waypoint names or your security settings in Sequoia?
Bernie
NE-FL, USA
2023 BMW R1250RT-TFT TripleBlack/BMW Motorrad Connected App & XT2
Riding around....collecting GPS tracks!
Has liked: 144 times
Been liked: 139 times
Post by danham »
epv wrote: Fri Jan 17, 2025 8:38 am I am finding that Basecamp is not usable on my Sequoia 15.2 M2 Macbook Pro - very frequently the window vanishes, and MacOS offers to send a crash report. I can sometimes manage to create a very small route but most manipulations of routes cause the crash. I wonder if there's something weird going on with my Basecamp install, since it seems like other people are using it successfully. I don't have much preserved data in it so I suppose wiping and reinstalling wouldn't be that awful, but I'd like an idea if it works ok for anyone first, I guess.
Before doing a "nuke and repave," I'd try deleting the BC preferences file. You will have to re-do your preferences, but that's a lot less work than starting from scratch. You can test by removing the plist file from its location and run BC. If that is not the problem, just put it back.
Javier
Spain
Re: Basecamp con el último IOS Sequoia
Post by Javier »
Not long ago I switched from Windows to Mac, I'm still learning iOS.
On my Mac mini M4 with Sequoia (15.4.1) BaseCamp works correctly with my XT2, I do the routes without problems and I pass them to the XT2 and without problems. This week I was able to verify it on a couple of trips.
The problem I have is that the XT2 is not detected as an external drive in the Finder of the Mac and I can't delete files.
With the memory card that I have installed I have no problems, from BC you can move the prepared routes and delete the data.
My old nuvi 2589 does not have that problem, it is detected as an external unit and the operation is correct.
Any solution to the problem, thank you in advance.
Greetings
Post by danham »
Javier,
You need the (free) app called Open MTP, which allows an Android device (XT) to appear in the Finder on your Mac. Older Garmins did not have this issue and neither does the SD card.
https://openmtp.ganeshrvel.com/
Javier
Spain
Post by Javier »
Thank you Danhan. I'll try it.
