Server Move Info
Need help with the forum? or got some forum feedback? Please use this section.
Has liked: 436 times
Been liked: 264 times
Server Move Info
As part of the server move I need to update the DNS records
Sometimes these can take a long time to update upto 24 Hours!
So if you find yourself on the old site after around 18:00 then you may need to clear your cache on your browser and flush your DNS records too
Instructions can be found here for flushing DNS https://www.whatsmydns.net/flush-dns.html
Please google how to clear your cache for the browser you are using
Also please not that clearing the browser can also stop the automatic login working so please try and remember your password
Hopefully things go smoothly and no one is left behind
Been liked: 560 times
Re: Server Move Info
@Stu, I hope it all goes smoothly for you. My fingers are crossed.
Sounds like a fun day.
Reminds me of every Summer Holiday when I had to set up all of the user accounts for the the new students, work areas, windows accounts, and then archive all of the accounts and folder contents for students who were leaving.
Fairly straight forward but full of opportunities for it to go completely wrong. ....
Like the time I had to ban admins from using laptops to access the server folders. My error. My finger slipped on the touch pad when I had a single folder selected, and I ended up moving all 1500 user accounts to a different folder. 2 hours later when it had finished (and I had managed to work out what had happened), they all had to be moved back again.
Hope it goes well @Stu. If it takes longer than you expect, blame it on the DNS update. We won't know any different !!
All should now be back online and working! I have some issues back end to sort though!
Let me know if you spot any issues :)
Smooth move. I would have been unaware of a change if you had not announced it. No need for DNS flush or any other action on this end.
Same here, nothing needed to be done on my end.
Thanks Stu
I think it's faster ! Not sure I'll be able to keep up
Yes its certainly a little bit quicker :)
