I have a Zumo 665LM. I had some issues when I loaded 2019.10 maps and then got the issue fixed, I think, with 2019.20.
Just tried to load 2019.30 using Garmin Express and it would only let me load the 49 states, could not load US and Canada maps. Could load Canada and the US border states.
I also have a 660LM with I had no issues loading the US and Canada maps.
I have a 16 GB Micro SD card. I thought it might be the problem so I changed it out with a spare 8 GB card. Still could only select the Lower 49 states.
Fully formatted the 16 GB card earning all files and tried again.
It appears that the maps will only load on the device and not the SD Card. I thought you could load maps on the SD card with Garmin Express but that may not be the case.
Tried using Garmin Mapinstall and while it seemed to load onto the SD Card, it always errored out at the last part of the process.
Does anyone have an thoughts/ideas about what I am doing wrong or what the issue might be.
I am using a Mac to do the map installs.
Zumo 665 Map Update Issue
- Has liked: 24 times
- Been liked: 35 times
Re: Zumo 665 Map Update Issue
There are a number of devices that Express won't install to a sd card. Your 660 is one of them. You need to install to your PC then use BaseCamp etc to install the map to the card.
- Wingstyle
- Has liked: 1 time
- Been liked: 11 times
sussamb, I believe the OP is having problems with a 665. His 660 seems to have worked.
I have a 660 and have loaded the last several maps with Garmin Express onto my microSC card. I just check my version with Garmin Express and I am at 2019.30. When I checked Garmin Express prompted it had an update, so I updated to version 6.11.1.0. I thought I had just updated Garmin Express not too long ago. I guess I'll see if it still works at the next map update.I also have a 660LM with I had no issues loading the US and Canada maps.
The 665 is one that wont install updates to device and sd card at same time, you have to install what fits on device at time of update and then use mapinstall to put remaining on sd card. I was disappointed when I ran into this as the 660 will do it all automatic and was cheaper than the 665.
https://support.garmin.com/en-GB/?faq=W ... =noProduct
Thanks that is very interesting information. This is the first time I have had an issue with the 665 about map size. I have traveled to Canada several times using the 665 and, in further past, my old 550 and always had the necessary maps. So, when I could not install the same maps on my 665 on this new map release, I was surprised.mwroma wrote: ↑Tue Jan 15, 2019 7:01 pm The 665 is one that wont install updates to device and sd card at same time, you have to install what fits on device at time of update and then use mapinstall to put remaining on sd card. I was disappointed when I ran into this as the 660 will do it all automatic and was cheaper than the 665.
I looked at the link provided and understand, I think, how it might work. So, I will undertake this process and see how it works out. It will be interesting.
As an aside, I have not looked to see what the map size is (memory needed) for the new maps. It would be interesting to see what the size was and the memory available the 660 vs 665.
I still have the 550 as well and trick Garmin express into doing the install on the SD Card. It has a worked several times. I have seen a YouTube video on doing that with a device other than a 550.
Thanks again for the information.
Just completed my map installation for my Zumo 665 as described in the link in mwroma's post.
It loaded and I verified that Canada road detail was now available (major roads were there before but not other roads and streets). So it worked.
What the Map info says is
CN North America NT 2019.30 Basic 3D
(1) Labrador - Newfoundland, Pemberton, British Columbia
(2) Lower 49 States
Thanks again. Maybe we should find some way to bookmark this on the forum so its obvious to all.
(2) Lower 49 States
