Zumo battery
Robert the Scot
Zumo battery
Post by Robert the Scot »
Hi guys. Just popped in here.
I'm from Perth, Scotland
I have a Garmin zumo 660.
I've had this for since 2014. Hardly been used.
I bought a new battery the other day.
I fitted it into the sat nav and a message came up on the screen and it won't go on charge
Insert battery.....
Can anyone please tell me what the problem is.
Robert
Been liked: 560 times
Re: Zumo battery
Greetings Robert. I'm sorry that I can't help you with your battery problem but can certainly welcome you to the forum, so...
Welcome to the forum from North Carolina, USA.
kernowing
Has liked: 135 times
Been liked: 61 times
Re: Zumo battery
Post by kernowing »
Welcome to the forum Robert from a fellow 660 user.
I guess you've cleaned the battery and unit contacts.
Did the unit start at all with the old battery installed?
Have you tried mounting the unit in the bike cradle?
2007 GL1800 Goldwing
Zumo 660LM
Re: Zumo battery
Welcome @Robert the Scot
What does the massage say exactly ?
How are you charging it. Some USB cables are single function - charge or synchronise. You may need a different cable.
Your new battery may be completely flat. I would put it in the powered cradle and take it for a long ride.
Your new battery may be duff. Contact the supplier.
Robert the Scot
Re: Zumo battery
I put it into the sat nav, the message just said
Insert battery.
The old battery works perfectly.
raesewell
Been liked: 20 times
Re: Zumo battery
Post by raesewell »
Robert the Scot wrote: Fri Feb 16, 2024 8:31 am
Which begs the question why do you need a new battery?
Robert the Scot
Re: Zumo battery
Sorry, the old battery won't charge completely it's ten old
Robert the Scot
Re: Zumo battery
Ten years old
kernowing
Re: Zumo battery
Post by kernowing »
Mine's over 10 years old and doesn't reach full charge. Not a problem really as I only use it in the car or bike cradles. Sounds like you've got a duff new battery!
Zumo 660LM
ZFtracker
Has liked: 22 times
Been liked: 39 times
Re: Zumo battery
Post by ZFtracker »
Welcome to the forum, Robert.
No 660 experience, I have a 590 (along with a Drive 60, Montana 610, and a inReach Mini), but it sounds like what others have said, a bad new battery.
Zumo 590
Montana 610
Drive 60
inReach Mini
