Maps Are Corrupt And Cannot Be Used
Jim1348
Has liked: 7 times
Post by Jim1348 »
When I power up my Garmin Zumo XT, I get the message, "Maps are corrupt and cannot be used. Go to www.garmin.vom/express to download the latest maps. OK"
How do I get rid of that message. The Garmin Zumo XT does seems to work just fine, despite that message.
MotoToph
Has liked: 28 times
Been liked: 15 times
Re: Maps Are Corrupt And Cannot Be Used
Post by MotoToph »
Did you re download the maps?
ZUMO XT
K1600GT
Jim1348
Has liked: 7 times
Post by Jim1348 »
Yes, I sure did.
Has liked: 361 times
Been liked: 375 times
Maybe not a Garmin map, have you installed any 3rd party maps?
Jim1348
Has liked: 7 times
Post by Jim1348 »
Yes, I have installed a number of non-Garmin 3rd party maps on it.
Has liked: 64 times
Been liked: 169 times
Remember that there should be only one active routable map for an area.
Un-check the non-Garmin maps in myMaps.
If the message persists, remove all the 3rd party maps and replace one at a time.
You could also try running JaVaWa's Device Manager and see if that throws up any errors
https://www.javawa.nl/jdm_en.html
Has liked: 111 times
Been liked: 156 times
sussamb wrote: 17 Dec 2023 07:59 You could also try running JaVaWa's Device Manager and see if that throws up any errors
Javawa's Device manager does not work for the XT. The XT uses MTP and that is not supported by Javawa Device Manager!
Ah yes, true. Shame
