Garmin withdraw map updates for older devices
- kernowing
- Has liked: 135 times
- Been liked: 61 times
Re: Garmin withdraw map updates for older devices
The 660LM is not mentioned, would that be covered by the 665LM GPS Navigator?
2007 GL1800 Goldwing
Zumo 660LM
Zumo 660LM
electro_handyman
- Has liked: 2 times
- Been liked: 41 times
I had a feeling it would be coming sooner than later for my 550..... not surprised one bit. Will continue with OSM maps.
MSTOCK27370
- Has liked: 22 times
- Been liked: 44 times
Do the OSM maps fix the problem with the new Garmin maps where the street names look like this C......... D....electro_handyman wrote: Fri Nov 03, 2023 10:11 pm I had a feeling it would be coming sooner than later for my 550..... not surprised one bit. Will continue with OSM maps.
Michael S.
Trinity, North Carolina
electro_handyman
The Garmin version I have is 2023.10 and they are abbreviated, my OSM I have is dated 2021 and they are not abbreviated.
What are osm maps? I can't update my 665.electro_handyman wrote: Fri Nov 03, 2023 10:11 pm I had a feeling it would be coming sooner than later for my 550..... not surprised one bit. Will continue with OSM maps.
Strange 660 still gets updates but not 665.
- lkraus
- Has liked: 87 times
- Been liked: 248 times
There are links to many sources here: https://wiki.openstreetmap.org/wiki/OSM ... n/Downloadhammer wrote: Tue Nov 07, 2023 5:10 am
Scroll down to the region you need, pick a source that offers routable maps, preferably with an installer compatible with your computer.
Although the underlying OSM data is the same, the maps can vary in appearance, detail, and coloring, so you may want to try several to see which one works best for you. Have only one active routable map on your Zumo at a time.
electro_handyman
Also make sure that you use the same map on your PC when making the routes... it will make your life a whole lot easier.lkraus wrote: Tue Nov 07, 2023 1:13 pmThere are links to many sources here: https://wiki.openstreetmap.org/wiki/OSM ... n/Downloadhammer wrote: Tue Nov 07, 2023 5:10 am
