Hi
I have had my Garmin Zumo XT a while and have learnt most functions, I have also learnt how to plan trips In Google Maps, export as a correct file format and see them on my Zumo, and hear is where my main challenge lies.
I see my collections on my Zumo XT that i have sent to the Zumo from importing into Garmin Maps.
But how on earth do I start the trip on my Zumo, I have gone to the appropriate collection and route, pressed it but nothing happens? I have imported as tracks, all the waypoints appear in my library, but all i want to do is start the route that is saved as a collection, and I can see it on my Zumo with the correct waypoints?
Thanks and like I say probably PICNIC syndrome, for those that aren't aware of this syndrome, Problem In Chair Not In Computer
Newbie with PICNIC syndrome
MD Clark_Hicks
- Has liked: 2 times
- Been liked: 560 times
Re: Newbie with PICNIC syndrome
In your XT tap the Apps button then the Trip Planner button then the Saved Trips button. You then select the route you want to ride. A list of the route points will appear. Be careful here because touching any of the flag icons will result in the route point being changed without a confirmation prompt (Via point will be changed to a Shaping point or vice versa). Of course you can intentionally change them. At the top is a Map button and a Go button. Tapping the Go button will prompt you for the point where you want to enter the route. Select it and then tap OK. The route will then start navigating.
BTW, welcome to the forum.
MD Clark_Hicks
Welcome to the forum
I will echo @Peobody's warning about touching the route points in that list - because it changes the type of point -
Flag to blue disc - ie a Via to a Shaping point
Blue disc to flag - ie Shaping point to a Via point
Both will result in the route being recacluated.
But changing a Via to a Shaping point may also have a very unwanted side effect. It renames the point and moves it to a different location.
Sometime the move is insignificant, but it can often move it to a point that diverts your route onto a faster road. If you placed the Via specifically to avoid the faster road, that is a serious issue. Reported January 2022, duplicated, acknowledged as an issue, still not fixed. (current version 6.60)
Changing a shaping point to a via point doesn't do this.
ps - In my opinion, there are much better ways of planning routes for the XT than with Google maps. But that is a completely different topic.
