Zumo
Airfiddler
Re: Zumo
I would start with a low battery, then remove it from the bike after a decent ride, and check the battery indicator again. this should tell the tale.
- Site Admin
- Has liked: 435 times
- Been liked: 263 times
Re: Zumo
on the 590 you can press and hold the battery icon and after about 5 seconds it brings up a page with loads of info on it
You can see if this screen if it is charging or on battery power
Try in on yours and see if it works
