Hello all and I have arrived with a problem!
I have a Zumo 660 660 ATL which has served me well over the last few years but as we are touring Europe this year I wanted to add some areas. Through Garmin Express, I received the message that there was not enough room on the device, so after a contact with Garmin tech it was suggested that I install a 32GB SD card which I duly did.
However I still see the same message of "not enough space" and although I can see from Garmin Express that the device is about 80% full & there is 31GB of card space, when asking to change maps I receive the same "not enough space message without an option to use the available SD storage.
Further contact with Garmin Tech received the suggestion to "bin it & buy another one from use at a 30% discount.
I don't really want to replace the unit - quite apart for the costs involved - it sees a bit mad that the device works but just needs a method of accessing the SD card storage. The SD card was formatted with the settings suggested by Tech - Fat32, Default Allocation Site and Quick Format.
Suggestions would be great,
Regards
Arthur.
Good Evening all.
- Has liked: 13 times
- Been liked: 32 times
Re: Good Evening all.
Use Mapinstall to load the map to the SD card. You can split it between the internal memory and the SD card. You have to make sure that you don't copy the same segment into both places.
Michael S.
Trinity, North Carolina
- kernowing
- Has liked: 128 times
- Been liked: 55 times
Good morning Arthur, welcome to the Zumo Forum.Arthur01 wrote: ↑Fri May 12, 2023 6:07 pm Hello all and I have arrived with a problem!
Regards
Arthur.
I have a Zumo 660 and had the same issues regarding loading all of Europe. Use Mapinstall and select the areas that you know you'll be touring and install the relevant areas.
2007 GL1800 Goldwing
Zumo 660LM
Zumo 660LM
Have tried the Mapinstall but it tells me there is not enough room on the device & does not see the SD card option.
