Trip Log / Track History Data
BashStreetKid
- Has liked: 32 times
- Been liked: 4 times
Can anyone kindly enlighten me which folder BaseCamp stores trip log/track history data on my PC hard drive?
I have searched in all folders known to man, on my PC, and zilch.
TIA
TIA
- Been liked: 561 times
Re: Trip Log / Track History Data
By default, BaseCamp data is stored in C:\Users\<username>\AppData\Roaming\Garmin\BaseCamp\Database. This is configurable though so could be different if a database has been created other than default.
You specifically mention trip log/track history which, to me, is device data not BaseCamp data.
BashStreetKid
@Peobody
Many thanks - that's exactly the folder I was after.
(Although it IS device data, it's stuff that's been saved from earlier adventures and shows up in BC when "tracks" are selected with two dark-grey bootprints.) I hope that makes sense....
It does, sort of. If they are tracks that were created on the device by a ride, I am curious how you got them into BaseCamp. I have never created a track on my XT so this is new territory to me.BashStreetKid wrote: Fri Apr 21, 2023 12:54 pm (Although it IS device data, it's stuff that's been saved from earlier adventures and shows up in BC when "tracks" are selected with two dark-grey bootprints.) I hope that makes sense....
BashStreetKid
Hmm, I'm going to struggle with this - my memory isn't what it was
The tracks pre-date my XT device; and, in fact, some are from fifteen years ago when I used a 660-model. Then, subsequently, an NAV IV device.
ISTR that I either saved them to my desktop direct from BC (in one of its earlier iterations) or transferred them direct from one of the devices. I know I used to transfer tracks to GoogleEarth quite easily from BC - but regrettably that facility has been removed over the years.
My five-year sojourn away from motorcycling/GPS have not been gentle on my memory
BashStreetKid
I have also transferred the track history / active logs to Google Earth, from the XT, within the past few months - if that's of any help?Peobody wrote: Fri Apr 21, 2023 12:27 pm ....
I'm not sure if I'm answering a question you haven't asked, yet?
BashStreetKid
@Peobody - I've had another look at this, using the XT device (I previously mentioned using tracks from different, older devices).Peobody wrote: Fri Apr 21, 2023 1:11 pm ....
1. If you wish to transfer an active log track from the XT-device, create a Folder and New List in the Library (LH upper pane).
2. Ensure the XT-device is connected, and search for the track logs (boot prints).
3. Select the active log in the Data Window, and then drag-and-drop into your newly-created NEW List in the Library. (You can see the transfer taking place with a thin green progress bar adjacent to the New List.)
4. A copy of your 'saved active log' will now be resident on your PC hard drive.
I hope all that makes sense and answers your question.
Good luck
Based on what I read in another thread, track logs are stored in a single file until archived. Based on that, I assume there is no control for selecting the track log of a specific ride.
I don't think this is anything I will ever use but I value the knowledge. Thanks @BashStreetKid.
BashStreetKid
You choose what you wish to save. Name it something memorable, and then it displays in BC library pane.Peobody wrote: Fri Apr 21, 2023 5:30 pm …… I assume there is no control for selecting the track log of a specific ride.
If a track has some intrinsic value to you, be that interesting scenery, nadgery roads, first trip to a strange country - the choice is yours. Then it’s up to you to save, as above.
I don’t save every track, only those of interest/value to me.
HTH
