Nav vs BC timing difference
electro_handyman
Been liked: 41 times
Re: Nav vs BC timing difference
Post by electro_handyman »
I'm hoping I don't stir the pot with my suggested theory on this....
Basecamp uses a flat speed value based upon defined road type, and yes that is adjustable in BC, but it does apply this value to the entire length of said road type.
XT has more updated speed zones that I'm presuming it does utilize for calculating route timing.
So if you have a "secondary" road that BC thinks is only a 45mph zone, yet local authorities have the zone set at 55mph, I'd think the XT would calculate at the 55mph rate and give you a faster route time for the same distance traveled.
Has liked: 144 times
Been liked: 139 times
Post by danham »
I believe that the speed and road classification data is contained in the maps, not the Basecamp app, so the behavior should be similar. BUT, it's also possible BC is coded to ignore or apply a simplified version of that data, so your theory may be correct.
The Activity profile in Basecamp contains a configurable average speed setting for different road types. So the question then becomes whether the average speed options are being used or whether the maps provide the speeds for calculating time.
