EU 2019.20 NTU - now available
mzeist
Has liked: 33 times
Been liked: 31 times
Post by mzeist »
as of 2018-08-30 available in Garmin Express
Groet, Marcel.
kernowing
Has liked: 128 times
Been liked: 55 times
Re: EU 2019.20 NTU - now available
Post by kernowing »
Thanks Marcel, I'll update my Nuvi tomorrow :)
2007 GL1800 Goldwing
Zumo 660LM
tojjer
Has liked: 25 times
Been liked: 20 times
Post by tojjer »
Nice one, thank you
Has liked: 77 times
Been liked: 44 times
Tried to download it to my 595 and it's kindly stripped out the 2019.1 maps, and throws an error up that it can't install them (the 2019.2) onto the GPSR!
Has liked: 311 times
Been liked: 356 times
What error? Just run Express again and you should be okay.
mzeist
Has liked: 33 times
Post by mzeist »
Also check if you have installed the latest version of Garmin express.
Groet, Marcel.
Has liked: 77 times
mzeist wrote: Mon Sep 03, 2018 6:15 am Also check if you have installed the latest version of Garmin express.
I'm sure that it is, but good idea. Downloaded the maps onto the PC so hopefully I'll be able to get them onto the 595 via Basecamp. As long as the error hasn't made the 595 an unrecognised GPSR.
I wouldn't recommend that. BaseCamp can only install the map, not all the other files that Express does, eg junction views
Has liked: 77 times
sussamb wrote: Mon Sep 03, 2018 9:15 am I wouldn't recommend that. BaseCamp can only install the map, not all the other files that Express does, eg junction views
Currently all I have is the base map on my 595. Thanks for that reminder though.
mzeist
Has liked: 33 times
Post by mzeist »
Maybe Garmin Express didn't delete all parts of the old map leaving not enough space for the new one..
one of the things you can do is check with javawa device manager.
http://www.javawa.nl/jdm_en.html
Groet, Marcel.
