Photo upload
- Site Admin
- Has liked: 437 times
- Been liked: 264 times
- Site Admin
- Site Admin
Re: Photo upload
Ah yes signatures require external hosting!
Although imgbb should still work all I will say is go careful of the size as signature images can turn out huge!
Try the code again and I will have a look at it once its in your signature and see whats going on
- Been liked: 561 times
Re: Photo upload
I know I am two years late but as a imgbb user I thought I would post that when inserting an image hosted on imgbb you need to use their Direct Link embed code url.
- Site Admin
Re: Photo upload
And I'm against external hosting as if something breaks with the links then the images are gone forever just like when photobucket decided to start charging a lot of people stopped using the service and a lot of images where brokenPeobody wrote: Thu Aug 11, 2022 6:37 pm I know I am two years late but as a imgbb user I thought I would post that when inserting an image hosted on imgbb you need to use their Direct Link embed code url.
At least with uploading them up to the server they will always stay here
I would never stop it mind I would just discourage it
Re: Photo upload
Adding an image in a signature requires external hosting. A loss there is not catastrophic though. Uploading the image as an avatar instead of putting it in the signature may be the better way to go.
- Site Admin
Re: Photo upload
Yes I was talking about just general images like you you are showing someone something has helpful then that help then goes!Peobody wrote: Fri Aug 12, 2022 12:46 pm Adding an image in a signature requires external hosting. A loss there is not catastrophic though. Uploading the image as an avatar instead of putting it in the signature may be the better way to go.
It's not the end of the world its just my preferred option then no risk of losing it that's all
