Moving Start point after transfer
Scarecrow
Been liked: 28 times
Post by Scarecrow »
Hi All
Is it possible to move the starting point of a route once its been transferred from Basecamp to XT :roll:
Re: Moving Start point after transfer
Don't think you can move the start point but what you can do is add a new point to a route in trip planner, then delete the original start point. Note you can't delete a start point, so you need to add the new start point in second place, then switch that point with the original start point so it is now in second place where it can be deleted.
Note I don't have a XT, but that's how trip planner works on all my Garmin devices.
Been liked: 1170 times
That works on the XT too.
Beware changing Vias to Shaping points on the XT. The location may be moved and the name changed. Use the shape tool to add, delete and move shaping points.
Scarecrow
Post by Scarecrow »
jfheath wrote: Mon Jun 27, 2022 8:33 am That works on the XT too.
Thanks for the heads up
