Thanks Wessiewessie wrote: Sun May 22, 2022 3:32 pmIt will show as an installed programme in Windows settings. Go to "Add/Remove" programme in settings. Simply type "add/remove" in the search box at the bottom left of your screen and follow the instructionsScarecrow wrote: Sun May 22, 2022 3:27 pmSorry Sussambsussamb wrote: Sun May 22, 2022 12:29 pm @Scarecrow
Have you tried deleting the downloaded map data already on your PC? Think you'll need to do that first, at least I did and it then worked.
I'm not That computer literate
but HOW do I delete the downloaded map data
I think that's sorted it
