I had a nuvi that needed the touch screen and digitizer replaced. You'd be surprised how damaged the touch was. I use a screen protector now and after 2 or 3 yrs it requires replacement. I guess it's the minute grit in glove material.
Latest XT Motorbike Lockable Mount options
- Has liked: 96 times
- Been liked: 201 times
Re: Latest XT Motorbike Lockable Mount options
The key word there being "may". If it does then remove it. If it doesn't you're golden.
- Has liked: 3 times
- Been liked: 19 times
Hi Simonsimoncrewe wrote: ↑Mon Feb 07, 2022 5:25 pm I have the Touratech mount, by far the most secure, as it surrounds the body of the XT & prevents the unit popping off the flimsy mount.
By the time you look at the Zumo lock & postage, you may as well buy the TT mount.
I have a mount cover with a KTM logo on mine when the unit is not installed - looks fine.
Where did you get the mount cover
- Site Admin
- Has liked: 400 times
- Been liked: 213 times
If you know someone with a 3D printer I have the file to make themScarecrow wrote: ↑Tue Mar 01, 2022 8:02 amHi Simonsimoncrewe wrote: ↑Mon Feb 07, 2022 5:25 pm I have the Touratech mount, by far the most secure, as it surrounds the body of the XT & prevents the unit popping off the flimsy mount.
Edit: here you go https://www.thingiverse.com/thing:4546658
- Site Admin
@Scarecrow There is also these https://www.gps.nl/motornavigatie/zumocoverxt.html
I bought two of these and they are pretty good
- Has liked: 41 times
- Been liked: 35 times
- Contact:
Yep, work well.Stu wrote: ↑Tue Mar 01, 2022 2:44 pm @Scarecrow There is also these https://www.gps.nl/motornavigatie/zumocoverxt.html
Colin
BMW R1250RS
BMW R1250RS
- Been liked: 1 time
It swings a tab out under the Zumo release button so you can’t press it.Scarecrow wrote: ↑Mon Feb 28, 2022 4:35 pm hi Guys
How does the Zumo lock work
e.g. Does it lock the mount release button or does it just stop access to the ram mount.
Might be me but I cant tell from the pictures.
As stated in the earlier post I have the Tourtech locking mount but its very shaky when riding.
- Has liked: 12 times
- Been liked: 5 times
I have the ZumoLock on 2 bikes (Multistrada and XR650L). I would rather have the Touratech as it locks the entire GPS instead of relying on the seemingly anemic plastic Garmin mount. However, the Touratech was back ordered and not available when I got the Zumo XT. I custom made aluminum mounts for the ZumoLock to attach to the bike.
Just to close this out - just installed the Zumolock on my Multistrada.
Needed to change the mounting holes I was using for my Garmin to get enough clearance under my screen - but otherwise pretty happy.
This won't stop a determined attack obviously, but I'm happy enough to use this when leaving my bike for short periods.
