Zumo
For everything Garmin Zumo 345/350 related
Trekker
Zumo
Post by Trekker »
How can you tell if the unit is charging ? On the bike .....it shows a green battery but no indication of it being charged as I ride :D :D 8 ?....hope this is not a daft question !
Airfiddler
Re: Zumo
Post by Airfiddler »
I would start with a low battery, then remove it from the bike after a decent ride, and check the battery indicator again. this should tell the tale.
Has liked: 131 times
Been liked: 74 times
Re: Zumo
on the 590 you can press and hold the battery icon and after about 5 seconds it brings up a page with loads of info on it
You can see if this screen if it is charging or on battery power
Try in on yours and see if it works :)
