Page 1 of 2
Nav V map updates
Posted: Tue Jun 04, 2019 5:48 pm
by doebag
Evening all.
Found my way here from the old forum.
I am having trouble updating the maps on a Nav V for a friend.
I managed to update the maps on my Zumo 660 and an old nuvi 255 easily, but have come to a dead end on the Nav V.
I have it added to my Garmin Express, and managed to update the software, but when I look for the maps update the only option I get is for adding speed cameras.
Any suggestions please ?
Re: Nav V map updates
Posted: Tue Jun 04, 2019 9:37 pm
by sussamb
Do you have lifetime maps for the Nav V? If Express isn't showing an update you may not, or there may not be an update for that model.
Posted: Wed Jun 05, 2019 1:20 pm
by doebag
sussamb wrote: ↑Tue Jun 04, 2019 9:37 pm
Thanks for the quick reply. I guess there are no map updates for the Nav V, as I have just retried my 660 and that only offers speed camera updates as well, now that I have updated it a few days ago.
Posted: Thu Jun 06, 2019 2:28 am
by electro_handyman
If you are wanting new maps for these units, have you looked into the Open Street Map option..
https://wiki.openstreetmap.org/wiki/OSM ... n/Download
http://garmin.openstreetmap.nl/
I've had to go this route to get new maps for my SP2820....
The maps appear to be as accurate as Garmin's, though the 'where to' database seems to be lacking a bit when searching......not that I'm complaining as you get what you pay for and these are free, or a donation if you feel inclined.
Posted: Thu Sep 17, 2020 5:06 am
by jack777
I've downloaded a couple of country maps but when I set up a route in Basecamp it shows as straight lines, like the Global map. Any suggestions as to what I've done wrong? Thanks Jack
Posted: Thu Sep 17, 2020 6:29 am
by sussamb
You may be using maps that aren't routeable or you have the direct activity selected in BaseCamp.
Posted: Thu Sep 17, 2020 6:30 am
by jack777
Sorry, what do you mean by "direct activity"??
Posted: Thu Sep 17, 2020 6:36 am
by sussamb
BaseCamp uses activity profiles, see Edit, Options, Activity profile. If you have the Direct activity selected then you get straight lines between points.
Posted: Thu Sep 17, 2020 1:07 pm
by MSTOCK27370
jack777 wrote: ↑Thu Sep 17, 2020 5:06 am
In BaseCamp, go to the "Maps" menu. You should see the new map that you downloaded. Make sure that the map is selected, not the Global Map.
- Capture.JPG (16.25 KiB) Viewed 9845 times
Posted: Fri Sep 18, 2020 5:47 am
by jack777
I did that but still straight lines.
Also when plotting a route in Europe, I have to keep changing the country map, as there is not a transition across borders - is there any way to have more than 1 map referenced at a time? Thanks Jack
