Learning and using Basecamp
tojjer
Has liked: 19 times
Been liked: 10 times
Post by tojjer » Fri Sep 28, 2018 9:51 am
Dusty ST wrote:
Thu Sep 27, 2018 1:40 pm
I find it's easier to do the initial planning on MyRoute using Google maps, and Streetview, then export, open in BC and check it's all on the right roads (it usually needs a tweak or two) before sending to the Zumo.
MyRoute also allows you to automatically add points along the route, which I turn to 'unannounced' in BC.
Hi, I've used the MyRouteApp, but find it too did the trying to send me to the end destination straight away.
I assume you use the "gold" membership to get the Google maps facility.
Do you save it as gpx1.0 or gpx1.1?
Dusty ST
Has liked: 7 times
Post by Dusty ST » Fri Sep 28, 2018 4:22 pm
I've not tried the MyRoute app, but a friend used it on a tour around France, Luxembourg, Germany & Belgium earlier in the month and found it was fine left to make up it's own routes, but it did get lost and confused following the routes I'd planned and used on my Garmin.
The Tom Tom and an older Zumo also used in the same group following my routes were generally the same, and was confirmed with bike to bike comms.
I save to GPX 1.1, which I believe also has the track, which also shows up when it's loaded in BC, so I can easily spot where the route strays from what I planned in MyRoute, and correct it.
Yes, I have Gold membership, so not sure what's not included in the freebie version, I've planned several years of UK and Euro tours, and am pretty happy with my planning routine, which always starts out on MyRoute where I do a lot of dabbling with ideas for routes which I don't find is as easy on BC.
tojjer
Has liked: 19 times
Post by tojjer » Fri Sep 28, 2018 4:27 pm
Brilliant, thank you
mickshere
Has liked: 8 times
Post by mickshere » Tue Feb 05, 2019 8:45 pm
Many thanks to all your advice guys, when i started looking at basecamp after using mapsource for about 10 years I was tempted to bin it and stay with my comfortable mapsource but I felt my new 595lm which is replacing my old 550 deserved a new approach /// the journey continues! :D
Steve W
Post by Steve W » Tue Feb 05, 2019 10:10 pm
Breezly
Been liked: 7 times
Post by Breezly » Wed Feb 06, 2019 5:13 pm
Ed Conde has updated the New England Riders Basecamp Tutorial and added Part 2, Advanced Routing.
http://www.newenglandriders.org/GPS/Learn_BaseCamp.htm
