Hi I have a new 595, on the wiring harness there is the poss and neg leads for power then 3 leads {mic, in and out) and also a rather handy USB charge lead, or so I thought. Mine and my friends does not work, I consulted the manual and sure enough it says that it only works with certain types of units. I also contacted Garmin on live chat who confirmed this but could not tell me which units it would or would not charge. I know some USB cables are data transfer and charge and some just charge but they should all be charge cables surely. I have tried it with my android phone an iPhone a power bank and the Bluetooth headset on my crash helmet and it does not work with any.
Does any one know if I have to activate it or which units it will work with or is it just not working.
USB charge lead
- Has liked: 96 times
- Been liked: 200 times
Re: USB charge lead
I originally thought I had a defective cable unit as the usb would not charge my motorola android phone, it worked only as an aux input when both the phone and gps are in place. I subsequently found out that the usb generally does not charge most modern devices from Yamaha and Kawasaki motorcycle forums.
- Has liked: 77 times
- Been liked: 44 times
Re: USB charge lead
Never had a problem with the USB lead charging things, as long as the GPS is in it's cradle and powered up. Doesn't give many amps out though.
Others have had a similar problem with their cradle, and here's one thread on it: https://advrider.com/f/threads/garmin-z ... m.1046684/
Re: USB charge lead
Exactly what I thought but no go with my smart phone, with gps in place it does not charge. Nor will it charge my very old mp3.Oop North John wrote: ↑Thu Sep 26, 2019 8:55 pm Never had a problem with the USB lead charging things, as long as the GPS is in it's cradle and powered up. Doesn't give many amps out though.
It's hit or miss whether it works or not. I've seen many more in the no-go column.
Re: USB charge lead
Thanks for the reply's and also the link to the other thread, It looks like there is no real answer to this at all and IMO it is a common fault that should be looked at by Garmin. I have not snipped the wires off but just left then neatly tucked away, nor will I be removing all my fairings yet again to install a replacement as I do Have another option for charging my Phone etc.
Re: USB charge lead
Ok guys just an update I have sorted it, The charge lead does work but you need to power the cradle with the unit fitted and turned on, so all good for charging your phone on the move.
